I'm on Vegas 23 build 356. Every time I skip a frame or perform any action, another "p" is added below the preview shown in the screenshot above, where it should be displaying stats like frame rate instead. Skipping to a different frame adds exactly 3 extra "p" every time. Eventually it exceeds the bounding box for the text there and vanishes.
In Project Preferences, the "Pixel aspect ratio" and "Frame rate" fields are pulling the bottom string from the Template drop-down menu (HDV 1080-24p 1440x1080), and those templates no longer display their frame rates but in some places display Chinese characters instead:
Text corruption exists in other places throughout Vegas. Eventually the program crashes because of it. Uninstalling Voukoder Pro fixes the issue. I have tried reinstalling both it and Vegas as well as removing all cached files and settings, didn't work.
Voukoder Pro 3 causes UI text corruption in Vegas 23 when using a comma-decimal locale Regional Format in Windows
17. Januar 2026 um 09:16 Hat das Thema freigeschaltet. -
Hello,
Build 356 was withdrawn on 18th December 2025 due to various issues including problems with the playback cursor on some systems. You should install previous version
Argonil
17. Januar 2026 um 22:35 Hat den Titel des Themas von „Voukoder Pro 3 causes UI text corruption in Vegas 23“ zu „Voukoder Pro 3 causes UI text corruption in Vegas 23 when using a comma-decimal locale Regional Format in Windows“ geändert.
