Dieses Thema
  • Dieses Thema
  • Dieses Forum
  3. Announcements
  4. Latest news and updates
VEGAS Pro 23
  • 10. September 2025 um 10:53
  • dominatoruk2
    Beiträge
    9
    • 4. Oktober 2025 um 22:56
    • #41
    Ok so now uninstalled FFmpeg8, and now downloaded and installed this: https://github.com/Vouk/ffmpeg/re…L.Installer.msi
    Is this the right one?
    I still cannot see Voukoder in render window :(
    Administrator
    Reaktionen
    656
    Beiträge
    3.211
    • 5. Oktober 2025 um 08:05
    • #42
    Did you check the "show all formats" checkbox?
    • Vorheriger offizieller Beitrag
    • Nächster offizieller Beitrag
  • dominatoruk2
    Beiträge
    9
    • 5. Oktober 2025 um 19:23
    • #43
    yes I did. Still nothing.
    I wonder if I should reinstall everything from scratch.
    Administrator
    Reaktionen
    656
    Beiträge
    3.211
    • 5. Oktober 2025 um 20:18
    • #44
    Can you start the designer app?
  • Funghie
    Schüler
    Reaktionen
    8
    Beiträge
    66
    • 6. Oktober 2025 um 12:04
    • #45
    Here are the steps that worked for me in case it helps:
    • Uninstall everything from Voukoder and FFMPEG (Check in C:\Program Files that there are no FFMPEG folders)
    You have to choose one or the other - I am currently using the V3 2026 beta option below. (But I did both these and they both work - just not together):
    For Voukoder version 2:
    • Install the FFMPEG GPL version that is available on the Voukoder V2 DL page
    • Install VoukoderPro-2.0.14
    • Get the zip file: VoukoderPro-2_VEGAS_Pro_23-v3.zip and copy those files as instructed into the Vegas 23 folder
    • Start the Designer and go to Register and make sure you are using the V2 Licence
    • Start Vegas 23 etc.
    For Voukoder version 3 2026 (beta):
    • Install the FFMPEG version 8 that is available on the beta DL page
    • Install Voukoder 3 2026 - latest beta, in this one there is an option to install to Vegas 23 as well as Vegas 22
    • Start the Designer and go to Register and make sure you are using the V3 2026 Beta Licence
  • dominatoruk2
    Beiträge
    9
    • 7. Oktober 2025 um 19:01
    • #46
    Where is "Voukoder 3 2026 - latest beta"?
    [Blockierte Grafik: https://ibb.co/hJCfR2B3]
  • Ger
    Beiträge
    10
    • 8. Oktober 2025 um 07:39
    • #47
    Sorry, but I don't understand...what should I actually change......You write: "and all I was changing was the DLL info in the Resources.rc file". But where can and should I do that...sorry for the inconvenience
    Administrator
    Reaktionen
    656
    Beiträge
    3.211
    • 8. Oktober 2025 um 07:56
    • #48
    Here: https://www.voukoder.org/forum/thread/1616
    There are more important information necessary and i didn't want to bloat the dowload page even more.
    I have added it to the installers (The 2026 BETA and to the Voukoder Pro update for VEGAS Pro 23). Just install or update it.
  • dominatoruk2
    Beiträge
    9
    • 8. Oktober 2025 um 15:57
    • #49
    Amazing thank you. I did the Voukoder 3 2026 option and now I finally see voukoder pro in my render list (yet to test it).
    This process has been very confusing to follow. I had to uninstall and re-install everything multiple times until I finally found this post. Also Voukoder 3 not being listed in the download section with easy, clear to read instructions has been quite confusing. I hope it can be made super clear for beginners in the future.
    Anyway, thanks for the tip. Will test now
  • dominatoruk2
    Beiträge
    9
    • 8. Oktober 2025 um 16:08
    • #50
    Actually scrap that, I have no idea what to do haha.
    Basically I now get these few YUVA options, whichever I clicked, I go to customise template which then opens Voukoder (designer thing?) and then I have no idea what to click in order to change the settings. If I just try to render by clicking one of these YUVA options then it says No Voukoder Pro scenes are defined yet. Please Create and select a scene first.
    [Blockierte Grafik: https://ibb.co/yMHcMG8]
    All seems so much more complex than when I had Vegas Pro 22 :(
  • Funghie
    Schüler
    Reaktionen
    8
    Beiträge
    66
    • 8. Oktober 2025 um 17:47
    • #51
    Yes, you need to create some scenes. I have always thought it would be handy to have some default presets already created there.
    I could upload some of mine for you, but it is not possible to attach files in this area of the forum, and I really don't want to use filesharing.
    Administrator
    Reaktionen
    656
    Beiträge
    3.211
    • 8. Oktober 2025 um 18:40
    • #52
    Documentation (In progress) - Voukoder Pro
  • dominatoruk2
    Beiträge
    9
    • 8. Oktober 2025 um 22:25
    • #53
    Zitat von Vouk
    https://www.voukoder.org/documentation/#3
    yeah i think i ran out of effort for this now :( I spent so many hours getting to this point hehe.
    If someone shares a preset that I can jsut copy and paste, then that would be ideal. Possible?
  • Funghie
    Schüler
    Reaktionen
    8
    Beiträge
    66
    • 9. Oktober 2025 um 12:46
    • #54
    Here's a couple of my scenes. You can open the designer and import them:
    Phil NV 15CQP.scene
    2 files sent via WeTransfer, the simplest way to send your files around the world
    we.tl
    This is a WeTransfer link, I only have a free account so it is valid for 3 days max.
  • dominatoruk2
    Beiträge
    9
    • 9. Oktober 2025 um 20:15
    • #55
    thanks a lot, i got them and will try importing and see what happens.
  • Funghie
    Schüler
    Reaktionen
    8
    Beiträge
    66
    • 9. Oktober 2025 um 20:50
    • #56
    They are both built for very high-quality render using nVidia GPU but at least you will be able to see how they are put together.
  • Marko65
    Reaktionen
    2
    Beiträge
    20
    • 1. November 2025 um 12:27
    • #57
    Hello, I see vouokoder in Magix Vegas 23, but vooukoder doesnt see scenes.
    I followed this instructions:
    This plugin will add VEGAS Pro 23 support to Voukoder Pro 2.x .
    Just install this by copying all files of this package (excluding this one) to your VEGAS Pro 23 directory (i.e. C:\Program Files\VEGAS\VEGAS Pro 23.0).
    NOTE: You have to check the "Show all formats" checkbox to see Voukoder Pro!
    P.S. This plugin only works with VEGAS Pro 23 and Voukoder Pro 2.
    Einmal editiert, zuletzt von Vouk (1. November 2025 um 12:37) aus folgendem Grund: Ein Beitrag von Marko65 mit diesem Beitrag zusammengefügt.
    Administrator
    Reaktionen
    656
    Beiträge
    3.211
    • 1. November 2025 um 12:38
    • #58
    Did you follow the instruction and create a scene first?
  • Marko65
    Reaktionen
    2
    Beiträge
    20
    • 1. November 2025 um 12:45
    • #59
    I have used my scenes long time, I see it in Magix Vegas 22, but not in Vegas 23. When I try customize template in Vegas 23, I dont see scene. In Vegas 22 yes.
    Administrator
    Reaktionen
    656
    Beiträge
    3.211
    • 1. November 2025 um 12:53
    • #60
    What version were you using before that VEGAS 23 update?
Ähnliche Themen
  • Voukoder Pro v2.0.10 with Vegas Pro v22
    • gregn928
    • 7. Mai 2025 um 19:48
    • General
  • VEGAS Pro is supported again
    • 18. Juli 2025 um 10:14
    • Latest news and updates
  • Confusion about the Voukoder
    • Hellforag13
    • 30. August 2025 um 23:34
    • General
  • Vegas Pro 23 support
    • marcinzmyslowski
    • 9. September 2025 um 12:43
    • General
  • Wrong scene stored with render preset in Vegas Pro
    • Noki
    • 6. September 2025 um 14:52
    • General
Benutzer online in diesem Thema
  • 11 Besucher
