    2. Get a trial license key
Dieses Thema
  • Dieses Thema
  • Dieses Forum
  3. Announcements
  4. Latest news and updates
VEGAS Pro 23
  • 10. September 2025 um 10:53
1. offizieller Beitrag
    Administrator
    Reaktionen
    635
    Beiträge
    3.093
    • #1
    VEGAS Pro 23 will be supported with the Voukoder Pro 3 version.
    I will drop a beta version most likely at October 1st.
    Note: It is important to check the "Show all formats" checkbox to see the Voukoder Pro plugin.
    • Nächster offizieller Beitrag
  • Funghie
    Schüler
    Reaktionen
    3
    Beiträge
    57
    • 14. September 2025 um 06:30
    • #2
    Great looking forward to it very much. I only just purchased Pro a couple of months ago so it would be quite a disaster to not have it in V23. :)
  • marcinzmyslowski
    Beiträge
    6
    • 14. September 2025 um 23:05
    • #3
    Could you be so kind and release this fix earlier than October 1st? Vegas Pro 23 was released one week ago and without this codec I am not able to render anything to my goal container and video and audio codec. Now VP23 is useless for me. I do apprieciate if you were able to release it earlier than October 1st.
    Administrator
    Reaktionen
    635
    Beiträge
    3.093
    • 15. September 2025 um 09:03
    • #4
    I'll see what I can do.
    • Vorheriger offizieller Beitrag
  • marcinzmyslowski
    Beiträge
    6
    • 15. September 2025 um 10:53
    • #5
    Ok Thank you. I do really apprieciate your efforts.
  • Marko65
    Reaktionen
    2
    Beiträge
    20
    • 16. September 2025 um 21:35
    • #6
    Is the upgrade from version 2.0 to 3.0 for free for existing owners? I Hope yes
    Administrator
    Reaktionen
    635
    Beiträge
    3.093
    • 16. September 2025 um 22:54
    • #7
    The beta license is for free and valid until the end of the year. You need to buy an update after it, or you can continue using version 2
  • Marko65
    Reaktionen
    2
    Beiträge
    20
    • 17. September 2025 um 22:24
    • #8
    But now I moved to Magix Vegas 23 and Voukoder 2 0 isnt compatible with it. Sorry, but I have to pay for Voukoder again?😩
  • Marko65
    Reaktionen
    2
    Beiträge
    20
    • 18. September 2025 um 10:58
    • #9
    I bought Voukoder recently, can't you make an exception? If version 2.0 worked with VP 23, I wouldn't need version 3.0, since I'm satisfied with version 2.0
  • Ger
    Beiträge
    10
    • 29. September 2025 um 08:43
    • #10
    Dat is best bijzonder..ik koop Voukoder Pro in de verwachting deze ook te kunnen gebruiken met Vegas Pro 23.....blijk ik weer een update te moeten kopen ?
    Administrator
    Reaktionen
    635
    Beiträge
    3.093
    • 29. September 2025 um 08:53
    • #11
    Next year the upgrade for VEGAS Pro will be an update in the Voukoder Pro installer.
    This year ... I'll work something out to give you all access to VEGAS Pro 23 asap.
  • Funghie
    Schüler
    Reaktionen
    3
    Beiträge
    57
    • 29. September 2025 um 13:13
    • #12
    tbh honest, I only bought Vouk a few weeks before it stopped working V22 and then moved to V23. So, I think since purchase I must have used it for about 3 renders, haha.
    This is not a complaint at all, but I think it would be nice to consider those of us who bought pro quite late in the day.
  • Marko65
    Reaktionen
    2
    Beiträge
    20
    • 29. September 2025 um 16:15
    • #13
    I agree with Funghie.
    I don’t need to switch to a higher version of Voukoder, but I want to use VP23.
    Vouk, I already asked once — would it be a problem to release version 2.15 that would be compatible with VP23?
    Administrator
    Reaktionen
    635
    Beiträge
    3.093
    • 29. September 2025 um 18:29
    • #14
    That's what I said earlier:
    But keep in mind: This will just happen with VEGAS Pro 23. So if VEGAS Pro 25 gets an API change and I have to release a new plugin ... this will be part of Voukoder Pro 2027. I won't make older versions of Voukoder Pro compatible with newer VEGAS Pro versions. Same applies for versions of FFmpeg.
    Maybe it is interesting to mention that I have also planned to release an alternative subscription license. So if you pay a monthly subscription license between 5 and 10 EUR you can use always the latest version. The current license option will also remain.
  • Marko65
    Reaktionen
    2
    Beiträge
    20
    • 29. September 2025 um 19:52
    • #15
    Sorry I didnt notice it. That´s good news :)
    Thanks
    Zitat von Vouk
    Administrator
    Reaktionen
    635
    Beiträge
    3.093
    • 29. September 2025 um 21:05
    • #16
    It is now on the download page.
  • Funghie
    Schüler
    Reaktionen
    3
    Beiträge
    57
    • 30. September 2025 um 08:34
    • #17
    Thanks for adding the DL of v2. As I need to work, I had no choice but to install that and uninstall the beta of 3.
    Notes:
    • V2 does not recognise ethe newer version of FFMPGE that was installed for b3, so that had to be uninstalled and the older version, from the V2 page) reinstalled.
    • Voukoder shows in the V3 about area - (funny many of us had tried copying and renaming those files previously)
    • Unfortunately, Voukoder does not show up as an actual Render Option even when making sure that all options are displayed in the render window etc.
    (Cannot attach image here to show above)
  • Funghie
    Schüler
    Reaktionen
    3
    Beiträge
    57
    • 30. September 2025 um 08:35
    • #18
    Also, cannot attach image and cannot edit typos... :-/
    Administrator
    Reaktionen
    635
    Beiträge
    3.093
    • 30. September 2025 um 08:59
    • #19
    That's why I explicity said: Don't install the beta on a production system! Voukoder Pro 2 does not accept FFmpeg 8. Reasons are:
    • The FFmpeg DLLs have different names
    • The ABI in the DLLs might have changed
    And especially don't mix version 2 and the the beta installations.
    What you should do now:
    • Carefully uninstall all Voukoder Pro installations
    • Uninstall the FFmpeg 8 installation
    • ONLY install Voukoder Pro 2 again and verify the license info is the version 2 license.
    (It is possible to install FFmpeg 7 and 8 in separate directories though. I have patched the FFmpeg 8 installers already)
    This should be working actually. What's your error message?
  • Funghie
    Schüler
    Reaktionen
    3
    Beiträge
    57
    • 30. September 2025 um 14:07
    • #20
    OK let me check all this. I did do a full uninstall. And don't worry this was not a complaint, I understand the issues with testing. I am sorry if it sounded like a complaint.
    About image and edit, I meant on the forum. It is Ok in the beta forum but here those options don't seem to exist. :)
Ähnliche Themen
  • VEGAS Pro is supported again
    • 18. Juli 2025 um 10:14
    • Latest news and updates
  • Confusion about the Voukoder
    • Hellforag13
    • 30. August 2025 um 23:34
    • General
  • Vegas Pro 23 support
    • marcinzmyslowski
    • 9. September 2025 um 12:43
    • General
  • Wrong scene stored with render preset in Vegas Pro
    • Noki
    • 6. September 2025 um 14:52
    • General
  • Voukoder Pro v2.0.10 with Vegas Pro v22
    • gregn928
    • 7. Mai 2025 um 19:48
    • General
Benutzer online in diesem Thema
  • 2 Besucher
Community-Software: WoltLab Suite™ 6.2.2
