Color shift in Voukoder Pro 2026.0.18.0
  • I'm seeing a subtle but clearly visible color/contrast shift when exporting from DaVinci Resolve using Voukoder Pro 2026.0.18.0.
    I tested the following:
    • Same Resolve project
    • Same source footage
    • Same GPU (RTX 5060 Ti)
    • Same NVENC encoder
    Results:
    • Voukoder Pro 2026.0.18.0 → visible color shift
    • Voukoder 13.4.1 → colors match the timeline correctly
    • Resolve native CineForm export → colors match correctly
    I also tested different Voukoder input formats (YUV 4:2:0, YUV 4:4:4, etc.) and RGB Mode settings. No change.
    Most importantly, the shift appears not only with HEVC/NVENC, but also with ProRes exported through Voukoder Pro. This suggests the issue happens before the encoder stage.
    MediaInfo reports correct BT.709 metadata, so the problem does not seem to be missing color tags.
    A while ago I had a similar FFmpeg issue (when converting videos via script) and fixed it by explicitly forcing Rec.709 conversion:
    -vf colorspace=all=bt709:iall=bt709
    -color_primaries bt709
    -color_trc bt709
    -colorspace bt709
    -color_range tv
    Could there be a color conversion regression in the Voukoder Pro pipeline compared to Voukoder 13.4.1?
    I'm uploading the original video and two conversions:
    VoukoderProTest
    Shared folder VoukoderProTest
    k00.fr
    This color shift makes Voukoder Pro unreliable for me. I didn't find a way to resolve this, so I'm going back to v13 for now.
    This is original:
    This is converted in Voukoder Pro:
  • Okay, I've actually tried to downgrade to v2.0.10, and guess what, everything is fine - no color shift. So, you've broken something in 2026 version. And not only that. Overall it feels laggier, the way scene designer opens up. When it opens up, it never shows the scene chosen in Davinci, it open some first scene, so you have to manually open the right scene. The arrow to resize window with Properties (Encoder Properties) doesn't show. That's just few of the things I've noticed.
