Dieses Thema
  • Dieses Thema
  • Dieses Forum
  3. Announcements
  4. Latest news and updates
Voukoder 11.3
  • 28. März 2022 um 21:49
    Administrator
    Reaktionen
    653
    Beiträge
    3.195
    • 3. August 2022 um 13:18
    • #21
    Voukoder 11.2
    Make sure you are using the latest connector for your application(s). For using NVENC (SDK 11.1.5) encoders driver version 471.41 or later is required.
    Fixes / Changes
    • Using NVIDIA SDK version 11 (This might drop support for older GPUs)
    • Built everything from stable sources again -> 20220725
    Credits
    Thanks to my all supporters by either PayPal, Patreon or BTC (33wJ6Jg3KbZA4ZMJMQBFMh7jxWFAnad1Lp). Also thanks alot to the translators.
    Top Patrons
    Gronkh, Schauerland, Andreas Martin Aanerud, Michael wooldridge and Chris Woods
    • Vorheriger offizieller Beitrag
    • Nächster offizieller Beitrag
  • Vouk 3. August 2022 um 14:18
    Hat den Titel des Themas von „Voukoder 11.1“ zu „Voukoder 11.2“ geändert.
  • annabel_shanderin
    Reaktionen
    1
    Beiträge
    17
    • 3. August 2022 um 15:14
    • #22
    Hi Vouk,
    11.2 fails to render anything for me. At least x264 and x265 as well as Nvenc h264/h264.
    It says: Failed to render the audio samples.
    Rolled back to 11.1 and I have no problem there.
    Administrator
    Reaktionen
    653
    Beiträge
    3.195
    • 3. August 2022 um 15:23
    • #23
    Can you post a log file (with low leven debugging) enabled please?
  • Oliver M.D
    Beiträge
    42
    • 3. August 2022 um 15:28
    • #24
    Only tested this once, but it exported no problem on my 1070 with 512.77
    Administrator
    Reaktionen
    653
    Beiträge
    3.195
    • 3. August 2022 um 19:15
    • #25
    Mea culpa! Please try 11.3.
    Administrator
    Reaktionen
    653
    Beiträge
    3.195
    • 3. August 2022 um 19:16
    • #26
    Voukoder 11.3
    Fixes / Changes
    • Migrated to NVIDIA NVENC SDK version 11 - You might have to update any saved settings!
      • This drops support for older GPUs
      • You are required to use the presets p1-p7 now. See: https://docs.nvidia.com/video-technolo…igration-guide/
      • The NVENC options "CBR_HQ" and "VBR_HQ" got removed. Please use "CBR" and "VBR" instead.
      • The "2pass" option has been replaced with "multipass"
    • Audio issues fixed
    Credits
    Top Patrons
  • Vouk 3. August 2022 um 19:16
    Hat den Titel des Themas von „Voukoder 11.2“ zu „Voukoder 11.3“ geändert.
  • annabel_shanderin
    Reaktionen
    1
    Beiträge
    17
    • 8. August 2022 um 16:21
    • #27
    Sorry about the late reply. I have just tested 11.3.2 and all is good now! Thanks!
  • FROM
    Beiträge
    2
    • 14. September 2022 um 08:30
    • #28
    Hi Vouk,
    I am using version 11.3.2 now. I have 2 PC for Editing on Adobe Premiere PRO. Version 22 built 169.
    Plus sometimes I am using After Effects.
    Tell me please what version of Voukorder will be better for these (not so fresh) cards?
    First PC has NVIDIA GTX 770 - Gigabyte GV-N770OC-4GD (rev. 2.0)
    Second PC NVIDIA GTX 970 - ASUS STRIX-GTX970-DC2OC-4GD5
    Please also let me know how will work and what version of Voukoder better for this new card -
    GIGABYTE|GTX 1660 SUPER|6 GB|192 bit
    (It looks like our old GTX 770 has sometimes problems. If it really stops, I think I will buy 1660 Super).
    Thanks!
    Administrator
    Reaktionen
    653
    Beiträge
    3.195
    • 14. September 2022 um 17:50
    • #29
    With Voukoder version 11.3 we migrated to NVENC SDK 11.1. This has dropped support for a couple of older GPUs.
    In case your GPU is affected please continue to use 11.2 for that system.
  • Oliver M.D
    Beiträge
    42
    • 17. September 2022 um 05:13
    • #30
    Any idea when we might be getting CRF for SVT-AV1?
    I think to remember you saying it needs FFmpeg 5.x, so I get it's not a over night change.
    Administrator
    Reaktionen
    653
    Beiträge
    3.195
    • 17. September 2022 um 07:15
    • #31
    You will get it next tuesday. Voukoder 12 will be released on 20.9.2022.
  • Oliver M.D
    Beiträge
    42
    • 17. September 2022 um 08:13
    • #32
    Not what I expected, thanks a lot! Interesting date tho.. is there a reason for it?
    Administrator
    Reaktionen
    653
    Beiträge
    3.195
    • 17. September 2022 um 08:40
    • #33
    Maybe? ;)
  • Oliver M.D
    Beiträge
    42
    • 18. September 2022 um 06:03
    • #34
    I shall await the eventual Nvidia related announcement then, hopefully it's AV1 related ^^
  • FROM
    Beiträge
    2
    • 11. Oktober 2022 um 10:19
    • #35
    I have on both editing PC with Adobe Premiere Pro these cards now:
    And it looks like with Voukoder 11.3.2 these cards working well.
    With right settings for Nvidia and Cuda / 30 minutes length program takes Export to 2160p about 17 minutes. And 16 minutes to 1080p. Quite good speed for me.
  • caraibe
    Beiträge
    3
    • 30. Oktober 2022 um 16:00
    • #36
    Hallo und herzlichen Glückwunsch zu Ihrem Soft, den ich empfehle
    Ich verwende immer die Version 0.8.2, die eine der ersten ist, mit CC2020
    Einfach ist sehr gut.
    Es ist jedoch nicht möglich, in HEVC HRD10 rec 2020 zu exportieren. Der Export funktioniert, aber das Ergebnis sind mehrere Fenster in Monochrom!
    Unterstützen Ihre neueren Versionen HDR et REC 2020 ?
  • caraibe
    Beiträge
    3
    • 30. Oktober 2022 um 19:02
    • #37
    Zitat von FROM
    Avec les bons paramètres pour Nvidia et Cuda / 30 minutes, le programme prend l'exportation vers 2160p environ 17 minutes. Et 16 minutes en 1080p. Assez bonne vitesse pour moi.
    Oui mais comme tu dis pas le temps de la vidéo ni les effets appliqués ça veut rien dire !
  • zainzli235
    Beiträge
    1
    • 28. Juli 2026 um 13:24
    • #38
    pls i need help the github link is not working it says error 404. even for voukorder 10,11,12
Ähnliche Themen
  • Voukoder 10.2
    • 21. September 2021 um 15:22
    • Latest news and updates
  • Voukoder 9
    • 3. Juni 2021 um 10:01
  • Instant Failure When Adding Video Side Data
    • Slipduwee
    • 1. Juli 2021 um 01:16
    • Closed bugs
Benutzer online in diesem Thema
  • 2 Besucher
Community-Software: WoltLab Suite™ 6.2.7
