    2. Get a trial license key
Dieses Thema
  • Dieses Thema
  • Dieses Forum
  3. Voukoder Classic
  4. Bug reports
  5. Closed bugs
NVENC BUG
  • lalalsi123
  • 8. Mai 2019 um 05:42
1. offizieller Beitrag
  • lalalsi123
    Reaktionen
    1
    Beiträge
    30
    • #1
    hi there is a bug on NVENC with MediaEncoderCC2019 number of B-frames i try from 1 to 4 no works.. in old ver.1.0.2 i have same preset, so it was on 2, and it works..but now on last 2.0.5 isnt myfull settings but not important BC it works good without B-frames. 2pass=1 b=3200000 bufsize=4550000 g=15 gpu=0 level=5.1 maxrate=3550000 preset=hq profile=main rc=vbr_hq rc-lookahead=1024 refs=3 tier=high LOG: This has most likely to do with an invalid combination of options. Make sure there is at least one free NVENC session and close all other programs that make use of NVENC. Please check if the used options and presets comply to the selected output level. Even the encoders default configuration (no options set at all) might not comply with all levels. Export Error
    Administrator
    Reaktionen
    635
    Beiträge
    3.094
    • 8. Mai 2019 um 06:36
    • #2
    Are you using h264 or hevc? What video card do you have?
    • Nächster offizieller Beitrag
  • lalalsi123
    Reaktionen
    1
    Beiträge
    30
    • 8. Mai 2019 um 12:16
    • #3
    ah, sorry i forgot. i use hevc nvenc
    card is 1070 drivers last ver for creators
    Administrator
    Reaktionen
    635
    Beiträge
    3.094
    • 8. Mai 2019 um 13:05
    • #4
    Unfortunately b-frames in hevc are only supported with RTX cards.
    • Vorheriger offizieller Beitrag
    Fortgeschrittener
    Reaktionen
    33
    Beiträge
    264
    • 8. Mai 2019 um 13:07
    • #5
    B-Frames with nvenc_hevc are only supported with 2000 series cards I think. Look here
  • lalalsi123
    Reaktionen
    1
    Beiträge
    30
    • #6
    eeeemm...why? nothing new in RTX...
    i look again sorry old preset was for h264 NVENC. but it sad nothing new in new cards to do this limit exept of shi.. rays
  • Vouk 8. Mai 2019 um 13:13
    Hat das Thema aus dem Forum Bug reports nach Bug reports verschoben.
  • Vouk 8. Mai 2019 um 13:14
  • MyPOV
    Schüler
    Reaktionen
    14
    Beiträge
    104
    • 8. Mai 2019 um 15:03
    • #7
    Not only RTX, with the new GTX 1660 / 1660Ti too, but not with GTX 1650.
    Administrator
    Reaktionen
    635
    Beiträge
    3.094
    • 8. Mai 2019 um 15:07
    • #8
    Lets say "The Turing architecture added supports for b-frames with hevc."
  • Vouk 22. Februar 2022 um 20:59
    Hat das Thema aus dem Forum Bug reports nach Closed verschoben.
Ähnliche Themen
  • NVidia Hardware Encoding (NVENC)
    • 21. April 2019 um 13:42
    • Knowledge
  • As a user I would like to export with HDR.
    • 18. April 2019 um 08:30
    • Closed feature requests
  • Immediate Error using NVENC using either HEVC or h.264 when selecting 10bit under the Voukoder
    • Drevil02
    • 3. Mai 2019 um 16:14
    • Closed bugs
  • Some suggestions regarding Beta2
    • Aex1
    • 3. April 2019 um 10:10
    • Closed bugs
Benutzer online in diesem Thema
  • 1 Besucher
Community-Software: WoltLab Suite™ 6.2.2
