libx264 settings
  • Hi all,
    Just installed Voukoder Pro version. Previously was using free version. I would like to export video using libx264, I have installed ffmpeg LGPL 8.1 and Voukoder Pro 3.2 can see LIBX264, so I am selecting it for video encoder settings. In the free version I used to set x264 using Preset, Profile, Tuning, Strategy (CRF) and buffers (max bitrate, buffer size), also GOP size. The rest are default values, I do not need to know what they are. But in Voukoder Pro version, do I have to set all rest of the values as well? Is that correct? Is there a way to bypass the rest of those default values, like in free Voukoder version, were those values were greyed out?
    Here are the screenshots of previous free Voukoder version vs. screenshot from Voukoder Pro.
  • Vouk 29. August 2026 um 06:31
    In the Pro version only the bold printed values will be used. In fact if they still match their default values they will be ignored. you can also see the this in the preview: only the values that are mentioned there will be finally applied.
