I can't seem to get libx264 two pass encoding to work in Voukoder Pro 3. I am using Premiere Pro and exporting to Media Encoder. I have the Passes setting in my Voukoder Scene set to 2 Pass but it only runs one pass , I've tried different other settings like setting rate control to be defined in x264-params and then setting bitrate, vbv-bufsize, and vbv-maxrate. None has worked. I am able to do two passes with Voukoder 1.x, not Pro 2.x, and now not Pro 3. Am I missing something here? Thank you.
Voukoder 3 libx264 Two Pass Encode?
ThreadVoukoder Pro 2.0.10 libx264 two pass VBR encoding?
I wasn't sure that a one pass libx264 VBR encode was possible since the strategy list only has CRF, CQ, and CBR. But if I choose CBR and give different bitrate and max bitrate values, I get VBR. But I don\e see a two pass option. There is a fast first pass option and a stats option though. I know that Vegas does not support two pass anyway but Adobe Media Encoder did (at least in 1.x). Is two pass possible in Voukoder Pro 2.0? Thank you.sryApril 24, 2025 at 8:05 PM Thread2 Pass x265 Encoding
Hey,
would it be possible to get 2 pass enccoding for libx265?
GreetingsPlannedrenvanAugust 24, 2025 at 3:53 PM -
- Official Post
That's correct. Two-pass (or multipass-encoding as you could also do a triple pass or n-pass) encoding is not built in yet. It's still on my todo-list. But I wanted to get the release done.
Thank you
