VEGAS Pro 23 crashes
  • Another update. I hope this will be the final one. The final release will come next (most likely). So ... just one month to go!
    Installed. Unfortunately, this seems to cause Vegas 23 to crash on start, so cannot get in to test it.
       Application Version: Version 23.0 (Build 328)
      Problem:             Unmanaged Exception (0xc0000005)
      Fault Module:        C:\WINDOWS\SYSTEM32\ntdll.dll
      Fault Address:       0x00007FF81D8DC1FE
      Fault Offset:        0x000000000001C1FE
    Fault Process Details
      Process Path:        C:\Program Files\VEGAS\VEGAS Pro 23.0\vegas230.exe
      Process Version:     Version 23.0 (Build 328)
      Process Description: VEGAS Pro
      Process Image Date:  2025-11-06 (Thu Nov 06) 23:25:10
    There are no associated Voukoder logs. So maybe this is a Vegas issue. However, I have not changed anything else on the system other installing b11 of Vouk.
    I will post back...
    Edited once, last by Vouk: Ein Beitrag von Funghie mit diesem Beitrag zusammengefügt. (December 1, 2025 at 1:31 PM).
  • Vouk December 1, 2025 at 2:55 PM
    Changed the title of the thread from “VEGAS Pro 23 crashes” to “[SOLVED] VEGAS Pro 23 crashes”.
  • Vouk December 2, 2025 at 8:15 AM
    Added the label Not a bug
  • Vouk December 2, 2025 at 8:16 AM
    Changed the title of the thread from “[SOLVED] VEGAS Pro 23 crashes” to “VEGAS Pro 23 crashes”.
