What video format does Vegas send data to the encoder, specifically Voukoder? RGB, YUV? 8-32 bits? Rec709? Limited range or full?
What format does Vegas send data to the Voukoder?
Depends on whats needed ...
- i420
- p010
- a410
Most encoder use YUV and I try to avoid any format conversions.
What version of Voukoder are you using?
Quite old, probably from 2 years ago.
I'm sorry to say the old Voukoder app is not supported anymore. I'm focussing on Voukoder Pro now.
Yes, I know, but the question also applies to the new Voukoder, because it seems that Vegas is sending a lower quality image to Voukoder than to other encoders --> https://www.vegascreativesoftware.info/us/forum/what-…ncoder--149851/
