hi so i have vegas pro 21 on steam and i've been trying to install voukoder pro/voukoder 13 and nothing seems to be working, yes it does install and stuff but it doesn't show up as a render option. i did use the vegas connector thingy and it still won't show up, please help me out
can't get voukoder to work on my vegas pro 21 (steam edition)
vzi
1. Oktober 2025 um 12:20 Hat den Titel des Themas von „can't get voukoder to work on my vegas pro“ zu „can't get voukoder to work on my vegas pro 21 (steam edition)“ geändert. -
1. Oktober 2025 um 12:23 Hat das Thema freigeschaltet. -
I'm not sure if a Steam-Edition is actually supported. You'd have at least to adjust the installation path of the VEGAS Pro 21 plugin to wherever Steam has installed VEGAS Pro 21. Normally I assume people install VEGAS Pro from the normal direct shop. But please keep me up to date if you got i working.
Normally Voukoder Pro installs the plugin to this path, but you can adjust this in the installer:
C:\Program Files\VEGAS\VEGAS Pro 23.0\FileIO Plug-Ins\voukoderproplug\voukoderproplug-vegas23.dll
