VEGAS Pro 23 doesn't render
  • Checked and double-checked license in Scene Designer and in \AppData\Local\VoukoderPro\license.txt
    License is definitely my license for Vouk V2
    I can repro the crash on render every time, but no log seems to be generated. I will attach the last log but I think it might not help.
    Also, anomalies?
    • Select my Vouk preset in Vegas
    • Click customize
    • Then Open Scene Designer
    • The Scene Designer shows blank page
    • Load my Scene into the designer
    • Save As but still shows blank
    • Also, when selecting another Vouk preset in Vegas and clicking customize
    • The Scene that is showing the Vegas customize dialog is always the same scene
    Sorry, there is no way to upload a log file or zip file here in this forum. I don't want use file sharing I will email it to you. With title "Log from Funghie".
    Cheers,
  • Hi, there are a lot of log files in:
    AppData\Local\VEGAS Pro\23.0
    I will email them to you as they may contain sensitive data.
    Indecently the issue with the scenes seems to have fixed itself. When I go to customize each of my render templates, it now shows the correct Vouk scene. But then when I open the scene, scene designer is blank. (not sure if this is relevant / or expected)...
    Edited once, last by Funghie (October 1, 2025 at 2:53 PM).
  • Vouk October 1, 2025 at 7:26 PM
    Changed the title of the thread from “VEGAS Pro 23 doesn't render” to “[SOLVED] VEGAS Pro 23 doesn't render”.
  • Vouk October 2, 2025 at 6:10 AM
    Changed the title of the thread from “[SOLVED] VEGAS Pro 23 doesn't render” to “VEGAS Pro 23 doesn't render”.
