Hi,
I need help. I'm trying to set the settings for HDR video in Voukoder Pro, but I'm doing something wrong because after encoding the video is not good.
When I encode the video with the old encoder the result is good as you can see from the example.
My settings for both encoders are attached. How to set Voukoder Pro to have the same or similar settings as in the old encoder.
Voukoder_HDR Settings.pdf Voukoder Pro_HDR Settings.pdf
Best regards
