    2. Get a trial license key
Dieses Thema
  • Dieses Thema
  • Dieses Forum
  3. Voukoder Classic
  4. Bug reports
  5. Closed bugs
2.0.6 crash
  • avwtp
  • 11. Mai 2019 um 06:06
1. offizieller Beitrag
  • avwtp
    Schüler
    Reaktionen
    5
    Beiträge
    98
    • #1
    x264 2 pass encoding, consistent crash but since there isn't a log file, can't give you any more info. Really can't tell you how much I can suggest the plugin go back to keeping a log file in $TEMP.
    I'm going to go back and try it with 1.2.1
  • avwtp
    Schüler
    Reaktionen
    5
    Beiträge
    98
    • 11. Mai 2019 um 09:19
    • #2
    Hold up it may just be my computer overclocking. Done hours of x264 at this setting, not seen it at this Ghz before.
    Fortgeschrittener
    Reaktionen
    33
    Beiträge
    264
    • 11. Mai 2019 um 13:48
    • #3
    Logfile still exists under Voukoder Settings Tab. You're right, overclocking could cause this crash.
  • avwtp
    Schüler
    Reaktionen
    5
    Beiträge
    98
    • 12. Mai 2019 um 05:15
    • #4
    It is an overclock issue. Caught me off guard.
    BIGGIE is that the if PPro or the plugin crashes, you can't get to the log file. Really want that old txt file backin $TEMP.
    Administrator
    Reaktionen
    634
    Beiträge
    3.078
    • 12. Mai 2019 um 07:45
    • #5
    The old log file is problematic when you are running two (or more) instances of voukoder at the same time.
  • Vouk 12. Mai 2019 um 07:46
  • Vouk 22. Februar 2022 um 20:59
    Hat das Thema aus dem Forum Bug reports nach Closed verschoben.
Ähnliche Themen
  • Second entry into plugin crashes Premier
    • avwtp
    • 25. April 2019 um 19:00
    • Closed bugs
Benutzer online in diesem Thema
  • 1 Besucher
Community-Software: WoltLab Suite™ 6.1.16
