Important VEGAS Pro Update!
  • Users having issues like these:
    • Your VEGAS Pro version is supported
    • VEGAS Pro doesn't show "Voukoder Pro" in the "Render" dialog
    • You have "Show All Formats" in VEGAS Pro checked.
    • ... but it appears in the About dialog unter Components as a loaded plugin?
    • ... and it just SHOULD appear as Render format?
    Please try this build and respond here if it works or still fails.
  • Hi, I am also unable to see Voukoder as a render option in Vegas Pro 2026 using this download and meeting the specified parameters noted above. Just my luck, it seems everyone else is getting it to work!
  • If you mean Voukoder Pro, yes, it is but you still need to copy the files from Vegas 2026. You can do it manually or use my bat:
    @echo offsetlocal enabledelayedexpansion
    echo ******************************************************************************echo Universal Voukoder Migration Scriptecho Script by Phil Pendleburyecho.echo Note: This script must be run as Administrator.echo ******************************************************************************echo.
    :: Check Administrator rightsnet session >nul 2>&1if %errorLevel% neq 0 (   echo ERROR: Administrator privileges are required.   echo Please right-click the script and select "Run as administrator".   echo.   pause   exit /b 1)
    :: Define supported directoriesset "dir[1]=C:\Program Files\VEGAS\VEGAS Pro 21.0"set "name[1]=Magix VEGAS Pro 21.0"set "dir[2]=C:\Program Files\VEGAS\VEGAS Pro 22.0"set "name[2]=Magix VEGAS Pro 22.0"set "dir[3]=C:\Program Files\VEGAS\VEGAS Pro 23.0"set "name[3]=Magix VEGAS Pro 23.0"set "dir[4]=C:\Program Files\BorisFX\Vegas Pro 2026"set "name[4]=BorisFX Vegas Pro 2026"set "dir[5]=C:\Program Files\BorisFX\Vegas Pro 2027"set "name[5]=BorisFX Vegas Pro 2027"set "totalVersions=5"
    :select_sourceecho Available VEGAS Installations:for /L %%i in (1,1,%totalVersions%) do (   echo   [%%i] !name[%%i]!)echo.set /p srcChoice="Select SOURCE version [1-%totalVersions%]: "if not defined dir[%srcChoice%] (   echo Invalid choice. Please try again.   echo.   goto select_source)set "sourceRoot=!dir[%srcChoice%]!"
    :select_destecho.echo Available Target Installations:for /L %%i in (1,1,%totalVersions%) do (   echo   [%%i] !name[%%i]!)echo.set /p dstChoice="Select DESTINATION version [1-%totalVersions%]: "if not defined dir[%dstChoice%] (   echo Invalid choice. Please try again.   echo.   goto select_dest)if "%srcChoice%"=="%dstChoice%" (   echo Source and destination cannot be identical. Please choose a different target.   goto select_dest)set "destRoot=!dir[%dstChoice%]!"
    echo.echo ==============================================================================echo Source:      !sourceRoot!echo Destination: !destRoot!echo ==============================================================================echo.
    :: Locate config file dynamically in source rootset "configFile="for %%F in ("!sourceRoot!\*voukoder*.fio2007-config") do (   set "configFile=%%~nxF")
    :: 1. Process Configuration Fileif defined configFile (   set "srcConfigPath=!sourceRoot!\!configFile!"   set "dstConfigPath=!destRoot!\!configFile!"
       if not exist "!destRoot!" mkdir "!destRoot!"
    if exist "!dstConfigPath!" (       set /p overFile="!configFile! already exists in destination. Overwrite? (Y/N): "       if /I "!overFile!"=="Y" (           copy /Y "!srcConfigPath!" "!destRoot!\" >nul           if !errorLevel! equ 0 (               echo Config file overwritten successfully.           ) else (               echo ERROR: Failed to overwrite config file.           )       ) else (           echo Skipped config file.       )   ) else (       copy /Y "!srcConfigPath!" "!destRoot!\" >nul       if !errorLevel! equ 0 (           echo Config file copied successfully.       ) else (           echo ERROR: Failed to copy config file.       )   )) else (   echo No Voukoder .fio2007-config file detected in source directory. Skipping.)
    echo.
    :: 2. Process Plugin Folderset "srcPlugFolder=!sourceRoot!\FileIO Plug-Ins\voukoderproplug"set "dstPlugFolder=!destRoot!\FileIO Plug-Ins\voukoderproplug"
    if exist "!srcPlugFolder!\" (   if exist "!dstPlugFolder!\" (       set /p overFolder="voukoderproplug folder already exists in destination. Overwrite? (Y/N): "       if /I "!overFolder!"=="Y" (           xcopy /E /I /Y "!srcPlugFolder!" "!dstPlugFolder!" >nul           if !errorLevel! equ 0 (               echo Plugin directory overwritten successfully.           ) else (               echo ERROR: Failed to overwrite plugin directory.           )       ) else (           echo Skipped plugin directory.       )   ) else (       xcopy /E /I /Y "!srcPlugFolder!" "!dstPlugFolder!" >nul       if !errorLevel! equ 0 (           echo Plugin directory copied successfully.       ) else (           echo ERROR: Failed to copy plugin directory.       )   )) else (   echo Source plugin directory not found at:   echo "!srcPlugFolder!"   echo Skipping folder copy.)
    echo.echo Process complete.pause
  • Trying Voukoder Pro on Vegas Pro 2027.
    Installer works fine and Voukoder shows up on Render Panel Options.
    But...
    When opening the render panel, if I select any other render type before first selecting Voukoder Pro, whenever I select Voukoder Pro then, all my scene options are gone. The Voukoder Pro panel presents me only HDCAM SR options.
    Whenever I first select Voukoder Pro as the renderer, all my regular render options are presented ok.
  • When opening the render panel, if I select any other render type before first selecting Voukoder Pro, whenever I select Voukoder Pro then, all my scene options are gone. The Voukoder Pro panel presents me only HDCAM SR options.
    Yes, I can confirm this, and it has been the same for a while. (Since B FX Vegas 2026).
    I found that Vouk presets still show as favourites (if they have been added as favourites.)
    I haven't found a simple repro or simple way to stop it but sometimes over the past period since BFX 2026, it simply stopped happening, then started happening again.
  • it shows up in 2026 however. I did find the show all it was unchecked so all were showing in 2027. Seems in 2027 I have everything correct as far as I can tell but ut soes not show up
