Plugin failing when trying to render in Vegas pro 22
  • After going through the forums, I was finally able to get Voukoder to appear in my list of options for rendering in Vegas Pro 22, but when I set up the scene and tried to render it just gives me an "Unable to start Voukoder Pro message with the following in the logs:
    I'm assuming this would be the helpful part of the log, but I'm not really sure at the same time. Any help would be appreciated
  • Vouk 30. Juni 2026 um 12:32
    Out of curiousity: What did you do to make it appear in VEGAS Pro after it did not appear? Many people are still struggeling with this issue and I can't find the reason for it.
    To your question: Can you switch the log level to "trace" and recreate the log file you showed above? The original low level error should be between this lines.
