Hello!
ive received an email that BorisFX brought a bunch of MAGIX IPs, Vegas Pro being one of them.
VP2026 is the latest Release, was trying a demo, and Voukorder Doesn't show up as a render. I was curious of this be a planned feature update at some point
Vegas Pro 2026 Support ( Now owned by BorisFX )
MoollyCow
31. März 2026 um 00:04 Hat den Titel des Themas von „VP 2026 ( Now owned by BorisFX )“ zu „Vegas Pro 2026 Support ( Now owned by BorisFX )“ geändert. -
31. März 2026 um 07:42 Hat das Thema freigeschaltet. -
This news is pretty new to me. I have to discuss this with the new owners first, and we'll see how it goes. With the insolvency of Magix mostly all of my contacts there have left.
I can't even find the VEGAS Pro download section for my VEGAS Pro 17-23 licenses on their website anymore ...
Hi there, yes, I came to ask this, I will test it and post back later, but in advance, I wondered if we had any idea if Voukoder will work with Boris Vegas
Does anybody know who is leading the VEGAS Pro development team now and has the email of him / her => Please PM me.
OK good news:
I have the full (licensed) version of Boris Vegas 2026 installed and running.
Voukoder Pro 2026:I simply copied the config file:
VoukoderProVEGAS23-x64.fio2007-config
C:\Program Files\VEGAS\VEGAS Pro 23.0
to:
C:\Program Files\BorisFX\Vegas Pro 2026
And the folder:
The folder (that containsvoukoderproplug-vegas23.dll)
voukoderproplug
C:\Program Files\VEGAS\VEGAS Pro 23.0\FileIO Plug-Ins
to:
C:\Program Files\BorisFX\Vegas Pro 2026\FileIO Plug-Ins
And Voukoder Pro 2026 works as normal.
There was no need to change any file names, or edit the config file, as the relative paths are still the same.I did get a firewall warning when rendering but it worked. And that will only happen once.
Cheers
i treid to do that, i couldn't get it to work, are you suing the 2.x version or Vouk 2026?
insolvency of Magix
Makes sense, they've been fire-saling Vegas Pro licenses for years. So you can bet the new owners will go to a subscription-based licenses instead, like Adobe.
Zitat
Voukoder Pro 3 causes UI text corruption in Vegas 23 when using a comma-decimal locale Regional Format in Windows
Unfortunately the same in Boris Vegas 2026. 😞
My Boris license is a permanent one, not subscription based. (My initial post/test was using the trial version. I bought the full license last night, once I had confirmed that everything works smoothly.)
I am using Voukoder Pro 2026, I have added some extra info to the post above, in case it helps.
