Adjustable NVENC Codec Tag
  • There is a practical compatibility issue with HEVC files encoded via NVENC. By default, Voukoder writes the hev1 codec tag, and such files do not play on iPhones. iOS expects the hvc1 tag – with it, the same file opens and plays without any issues.
    As a result, after encoding I have to do an extra remux step via ffmpeg just to change the tag using -tag:v hvc1, without re-encoding. This is purely a container-level fix, but it adds unnecessary friction to the workflow.
    It would be very helpful to have a simple option in the settings to specify a custom codec tag for HEVC output (or override the default), so this remux step can be avoided entirely.
    This does not affect quality or encoding itself, only playback compatibility on iOS devices.
  • Vouk January 27, 2026 at 2:06 PM
    Approved the thread.
  • Vouk January 28, 2026 at 6:32 AM
    Added the label Implementing
  • Vouk August 5, 2026 at 1:13 PM
    Set the label from Implementing to Done
