Voukoder not showing in Vegas Pro 14
  • Good morning. I just installed an old free version of Voukoder, version 13.4.1, as well as version 1.5.0 of the Vegas 12-17 connector.
    When I open the “Render As” window, the Voukoder option does not appear. Does anyone know how I can fix this? I am using Vegas Pro 14 (Build 270).
    Voukoder does not even appear in Tools > Extensions.
    This is the specific version I installed.
    Edited once, last by bubblesplash (January 5, 2026 at 3:28 PM).
  • Vouk January 5, 2026 at 8:04 PM
    Approved the thread.
  • Sorry, but the old version of voukoder is not supported anymore. I also never tested it with with VEGAS Pro 14.
    I doubt anyone will reply to this message. The forums are made invisible intentionally.
  • Well maybe we're finally learning where the cutoff line is.
    Vegas Pro 12.0 doesn't work.
    Vegas Pro 15.0 DOES work with Voukoder
    BTW, Voukoder never appears in Extensions, even in a successful installation.
    Check your About -> Components, make sure voukoderplug.dll is installed in Vegas.
  • I just noticed that the voukoderplug.dll file did not appear in the FileIO Plugins folder in Vegas Pro 14, but it DID appear in version 15 (which I uninstalled due to performance issues), so I had to copy that .dll file to C:\Program Files\VEGAS\VEGAS Pro 14. 0\FileIO Plug-Ins\voukoderplug\, as well as the Voukoder-x64.fio2007-config file in C:\Program Files\VEGAS\VEGAS Pro 14.0\, and it actually worked.
    I did some testing with the Voukoder settings, such as changing it to “very fast” and also the H.264 (AMD AMF) codec, and I did notice an improvement in export speed in Vegas Pro 14 compared to the default settings, even with a low-end laptop.
    Thank you Joe24 for your help.
