The next version has been dropped: The windows version of Voukoder Pro 2026
The mac version will follow. It basically compiles already but i still have issues with codesigning, notarization - which is required for mac apps since tahoe.
Changes / Fixes
- Core
- Disabling a track doesn’t cause Voukoder Pro to create an empty track anymore
- If FFmpeg could not be found inform the user in a user friendly message
- It’s possible overwritten filenames can contain apostrophes
- Muxer options (i.e. +faststart) are working again
- Using FFmpeg 8.0 now
- Sorting video tracks first, audio tracks are second
- Optimized the compiler flags that resulted in around 8% performance increase
- Validating the license seat count more reliably
- Logging
- Added the menu option to open the log dir.
- Added a dropdown box in the settings to change to log level
- Added a check box to the settings to enable or disable the logging
- Added colors to the scene test log view
- Added the option to select the number of days when to delete log files
- Printing the system information at the beginning of each log file
- Added a “Copy to clipboard” button
- NLE Plugin
- [VEGAS Pro 23] Added a new plugin.
- [VEGAS Pro] Probably fixed the issue Voukoder Pro is not displayed to some users
- Designer
- Added back IAvoe’s presets [FFV1, libsvtav1, libx264 and libx265 encoders (if present)]
- The Designer supports re-opening the last open tabs
- Supporting different 5.1 audio channel layouts now (Selectable over the input node)
- It is now possible to add the ISO date and time when overwriting the file name in the file properties.
- The “About” dialog has been reworked so you can see more information about your license.
- Added a textual description to all video pixel formats and audio sample formats
- Extended the “Open-Scene” dialog in the designer.
- You can now select and open and delete multiple files.
- There is also a new button where you can rename a single scene.
- Scene Test
- Made the simulated video- and audio tracks editable and deletable again
- Fixed measuring the time (and corrected the fps) in the scene test
- Languages
- Added translations for multiple other languages:
- Chinese
- Japanese
- Korean
- Russian
- Brazilian (Portuguese)
- French
- Spanish
- German
- (Tell me if you need more, please also report if translations are not correct)
- Installer
- Expanded the VEGAS Pro Plugin section, so users are more aware they have to check their version here
- Licensing (Added an alternative, monthly subscription model license, still to come)
