Hello, I've recently purchased the pro version after using the free one for a year in Vegas 22, but now, after a fresh windows installation, I can't get the pro version to work with neither Vegas 22 nor Vegas 23.
What I did was:
1. Installed FFmpeg from the GPL installer in the Downloads tab
2. Installed Voukoder Pro 2 V2.0.14 and copied the files for the Vegas 23 v4 zip into my Vegas 23 folder
3. Registered and created a scene in the Voukoder Designer
But sadly the Vokouder render options do not appear in any Vegas version. I did check the "show all..." box too.
I also see the voukoder dll in the help>about>components section within the software, but still it won't show up in the render list.
I'd appreciate any suggestions, thanks!
