Is it possible to pass variables to the post-processing node?
  • I've still never gotten Adobe Media Encoder to work correctly with Pro, but I decided to whack my head against it again :) But that's for a different thread.
    I've been poking at youtubeuploader, which is a CLI tool to upload videos to youtube, and it seems to work correctly when invoked by Postproc nodes in the Designer. However, I don't see an obvious way to use individual file names in the process.
    My test setup is basically this: I've got a normal setup in a copied scene, so that I know the output file is fine; I can then add a Postproc node after the Output (file) node that runs youtubeuploader. The syntax for uploading is youtubeuploader -filename <filename>.mp4, which means I'd need to use the same generic name for every rendered video, since it's hard-coded into the Exec line in the Postproc node. While workable, I'd really like to avoid that, especially when I have a couple renders queued up!
    Before I whip up a script to guess & rename the video before upload, I just wanted to check to see if there was a built-in way to pass the variables from the Output node to the Postproc node(s), to save some trouble!
    Okay, I just found out this isn't mentioned anywhere, but these variables are available ...
    $(FilePath)
    $(FileName)
    $(FileExtension)
    $(FileFullname)
    So this should work:
    youtubeuploader -filename $(FileFullname)
    Putting it on my list ...
