AV1 CPU Encoding in Voukoder Pro
  • Hello, I have used Voukoder for years now and want to switch over to Pro. I am trying to recreate some of my templates that I have in Vegas from the old Voukoder into Pro but am having trouble in distinguishing between CPU and GPU encoder types. I am wanting to use AV1 using my CPU to render, but I am not sure which encoder option to pick in the list. In the old version, it was called this:
    In Pro, I see some AV1 options, but I don't know which is the equivalent to the above. The list of encoders has the headers of AMD, General, Intel, Microsoft Media Foundation, Nvidia, and VA-API. I am guessing that the AMD, Intel, and Nvidia would be GPU encoders using those graphic card brands (correct me if I'm wrong), so then I would assume that the CPU encoder would be under General. When looking in General, I see LIBAOM-AV1, but idk if that's the same. Can someone help me? And thank you in advance :)
  • Vouk May 14, 2025 at 6:58 AM
    Approved the thread.
