Final Cut Pro X support?
  • i couldn't find any posts on these forums about final cut pro x support.
    Do you plan on adding support, assuming it allows such plugins?
    If you don't own a mac or final cut pro x i'm sure there would be enough people willing to contribute for you to buy a new mac mini which costs €799, final cut pro x costs €330, so €1130 total cost.
    Approved the thread.
  • I need a Voukoder version that'd compile on a Mac first. The Voukoder successor is planned to do so (also on Linux). Then, if a Final Cut plugin SDK is available I could support it too.
