Failed opening codec using 2.3 beta 5 with Premiere conector
  • Encoder x264 and x265
    Pixel Format 4:2:0 8, 10, 12 bit give straight up the error, encode lasts 0 seconds and the log says encoder not found, 4:2:2 and 4:4:4 are working fine
    I don't know what HAP is but doesn't seem to work
    Any other pixel format across codecs works so far, FFV1 its the only one that works with 4:2:0
    2019-11-27 .log.txt
    Added the Label In Progress
    • Official Post
    The issue is that at least one pixel format has to be mentioned here:
    Quote
    [14:00:04] Opening codec: libx264 with options:
    Normally this has to be yuv420p by default.
    Please try loading, saving and loading the settings again.
    If it still fails delete all saved presets/templates and start with a clean new project.
    Set the Label from In Progress to Not a bug
