Please help...
2026-01-01 19:16:51 (info) [VoukoderPro.cpp:86] Voukoder Pro BETA 3.0.15.0
2026-01-01 19:16:51 (info) [VoukoderPro.cpp:87] (C) 2023-2026, Daniel Stankewitz
2026-01-01 19:16:51 (info) [VoukoderPro.cpp:88] ---
2026-01-01 19:16:51 (info) [VoukoderPro.cpp:103] Deleting now all log files older than 7 days ...
2026-01-01 19:16:51 (info) [VoukoderPro.cpp:116] Finished deleting 0 log files older than 7 days.
2026-01-01 19:16:51 (info) [VoukoderPro.cpp:750] System information:
CPU(s):
Socket 0:
Vendor: GenuineIntel
Model: 13th Gen Intel(R) Core(TM) i7-13650HX
Cores: 14/20
Memory:
Total: 32768 MB
Free: 25513 MB
Available: 25513 MB
GPU(s):
Card 0:
Vendor: NVIDIA
Model: NVIDIA GeForce RTX 4050 Laptop GPU
Driver version: 32.0.15.9144
Card 1:
Vendor: Software by KeloCube
Model: SuperDisplay Virtual Adapter
Driver version: 3.47.17.59
Card 2:
Vendor: Intel Corporation
Model: Intel(R) UHD Graphics
Driver version: 32.0.101.7082
Storage:
Disk 0:
Vendor: (Standardlaufwerke)
Model: WD PC SN560 SDDPNQE-1T00-1002
Serial number: E823_8FA6_BF53_0001_001B_448B_4ED6_AA7E.
Disk 0:
Model: Samsung SSD 980 PRO 1TB
Serial number: 0025_38B6_31B9_AD8F.
Operating System:
Name: Microsoft Windows 11 Home
Version: 26200
Architecture: 64 bit
2026-01-01 19:17:32 (info) [VoukoderPro.cpp:201] Validating license ...
2026-01-01 19:17:32 (info) [VoukoderPro.cpp:210] License is valid!
2026-01-01 19:17:32 (info) [VoukoderPro.cpp:211] Counting seat usage ...
2026-01-01 19:17:33 (info) [NetworkLicenseChecker.cpp:91] Active seats: 1 / 1 seats
2026-01-01 19:17:33 (debug) [NetworkLicenseChecker.cpp:119] License responder started ...
2026-01-01 19:17:33 (info) [Router.cpp:110] ### PHASE: PRE-INIT
2026-01-01 19:17:33 (debug) [InputNode.cpp:90] Filter config: buffer@8b037f7299f649c6abb8376f66606f7d=width=1920:height=1080:pix_fmt=yuv420p:time_base=1/25:pixel_aspect=1/1,format=pix_fmts=yuv420p,buffersink@6fe349a2dbae4e638de62f0441e1c969
2026-01-01 19:17:33 (info) [Router.cpp:120] ### PHASE: INIT
2026-01-01 19:17:33 (debug) [InputNode.cpp:160] Dumping filter graphfor NLE Track #0:
| buffer@8b037f7299f649c6abb8376f66606f7d |default--[1920x1080 1:1 yuv420p]--Parsed_format_1:default
| (buffer) |
buffer@8b037f7299f649c6abb8376f66606f7d:default--[1920x1080 1:1 yuv420p]--default| Parsed_format_1 |default--[1920x1080 1:1 yuv420p]--buffersink@6fe349a2dbae4e638de62f0441e1c969:default
| (format) |
Parsed_format_1:default--[1920x1080 1:1 yuv420p]--default| buffersink@6fe349a2dbae4e638de62f0441e1c969 |
| (buffersink) |
2026-01-01 19:17:33 (info) [EncoderNode.cpp:126] Initializing video encoder: h264_nvenc
2026-01-01 19:17:33 (info) [OutputNode.cpp:148] Successfully initialized the output format.
2026-01-01 19:17:33 (debug) [InputNode.cpp:90] Filter config: abuffer@01f34c08e2ff4cc78a7a8fb3e1070d11=sample_rate=48000:sample_fmt=flt:channel_layout=stereo,aformat=sample_fmts=fltp,abuffersink@75617258c2c9468f8e2a5ca8698fc363
2026-01-01 19:17:33 (debug) [InputNode.cpp:160] Dumping filter graphfor NLE Track #1:
| abuffer@01f34c08e2ff4cc78a7a8fb3e1070d11 |default--[48000Hz flt:stereo]--auto_aresample_0:default
| (abuffer) |
auto_aresample_0:default--[48000Hz fltp:stereo]--default| Parsed_aformat_1 |default--[48000Hz fltp:stereo]--abuffersink@75617258c2c9468f8e2a5ca8698fc363:default
| (aformat) |
Parsed_aformat_1:default--[48000Hz fltp:stereo]--default| abuffersink@75617258c2c9468f8e2a5ca8698fc363 |
| (abuffersink) |
abuffer@01f34c08e2ff4cc78a7a8fb3e1070d11:default--[48000Hz flt:stereo]--default| auto_aresample_0 |default--[48000Hz fltp:stereo]--Parsed_aformat_1:default
| (aresample) |
2026-01-01 19:17:33 (info) [EncoderNode.cpp:126] Initializing audio encoder: aac
2026-01-01 19:17:33 (info) [Router.cpp:164] Initialization succeeded.
2026-01-01 19:17:33 (info) [Router.cpp:176] ### PHASE: PRE-OPEN
2026-01-01 19:17:33 (info) [EncoderNode.cpp:286] Registering 1 video stream(s)
2026-01-01 19:17:33 (debug) [OutputNode.cpp:294] Registered stream 6fe349a2-dbae-4e63-8de6-2f0441e1c969:0
2026-01-01 19:17:33 (info) [EncoderNode.cpp:286] Registering 1 audio stream(s)
2026-01-01 19:17:33 (debug) [OutputNode.cpp:294] Registered stream 75617258-c2c9-468f-8e2a-5ca8698fc363:1
2026-01-01 19:17:33 (info) [Router.cpp:187] Pre-open phase succeeded.
2026-01-01 19:17:33 (info) [Router.cpp:188] ### PHASE: OPEN
2026-01-01 19:17:33 (info) [EncoderNode.cpp:387] Opening video encoder plugin 'h264_nvenc' with params '{"rc":"constqp","qp":23,"g":12,"bf":0,"preset":17,"profile":2}'
2026-01-01 19:17:33 (info) [EncoderNode.cpp:387] Opening audio encoder plugin 'aac' with params '{"rc":"cbr","b":256000,"profile":"aac_main","cutoff":17000}'
2026-01-01 19:17:33 (error) [EncoderNode.cpp:396] Opening the encoder plugin failed with error code: -22
2026-01-01 19:17:33 (error) [Router.cpp:194] Open phase failed: -11
2026-01-01 19:17:33 (info) [VoukoderPro.cpp:650] Unable to open a Voukoder Pro session. Please check the log file.
