Better Renders for Vegas 23
  • I'm having an issue where my render output with Voukoder Pro on Vegas 23 is capped at only 30fps, when normally I'd prefer 60fps. Normally that wouldn't be a big deal but it doesn't look great and given the freedom of customization with Voukoder Pro I'm not sure how to go about making it look better. I'm used to using the previous Voukoder connectors for older versions of Vegas but now that I'm on version 23 and the connectors no longer work I'm having a lot more trouble getting good renders.
  • Vouk 15. November 2025 um 05:49
  • This has been fixed already. What version of the VEGAS 23 plugin are you using?
    I'm using 3.0 beta version I believe
    I reverted back to 2.0 and it fixed it :thumbup:
    Einmal editiert, zuletzt von Vouk (18. November 2025 um 05:18) aus folgendem Grund: Ein Beitrag von killbenito mit diesem Beitrag zusammengefügt.
  • Vouk 2. Dezember 2025 um 08:18
