Confusion about the Voukoder
  • So i was using voukoder for almost a year, before it became "Pro"
    i remember it had a download link for sony vegas pro 13, i cant find it anywhere. The github link is gone/down.
    I just registered to try to find an answer because im a bit confused on how to get it.
    Does Voukoder even work with Sony Vegas pro 13 now? I had seen a post that the developer returned the support for vegas pro (18-23 version only?)
    im very confused, pls help
    sorry if i used wrong tag or flair or anything, i just registerd out of frustration.
  • Vouk 31. August 2025 um 07:27
    It's really interesting VEGAS Pro is one of the few tools where older version are still in use by many people. But we can try to support as many older versions that are supported by the oldest VEGAS Pro SDK I have access to.
    I'm just busy with Voukoder Pro 3 at the moment. I'll put it on my todo list.
  • Voukoder never included a download link for VEGAS Pro. My first version of VEGAS Pro was 17 which SDK should be compatible down to VEGAS Pro 12, but i was never able to test it.
    Voukoder Pro supports VEGAS Pro 18-23 now.
    yes, it worked on SVP 12 for sure, but it was like vokouder 1? all i remember when you had a link to your github archive there was a bunch of old vokoder files
