All Encoding Fails with Voukoder Pro in Adobe Premiere Pro 25 and Media Encoder
  • Dear Voukoder Support,
    I am encountering a consistent and critical issue with Voukoder Pro when exporting any project in Adobe Premiere Pro version 25 and Adobe Media Encoder. The problem occurs with every encoder type, not just NVENC. I have tested multiple encoding formats including hevc_nvenc, h264_nvenc, libx264, and libx265 — all result in immediate export failure.
    What I’ve Tried:
    • Deleted all custom scenes and started fresh using the Simple export mode
    • Tried both video-only and audio-only exports
    • Exported from Adobe Premiere Pro 25 and Adobe Media Encoder
    • Changed renderer settings to Mercury Playback Engine Software Only
    • Updated NVIDIA GPU drivers (tried both Studio and Game Ready)
    • Switched between AAC, PCM, and other audio encoders
    • Set different file output paths and file names
    • Reinstalled Voukoder Pro and its Adobe Connector
    Premiere Pro
    Error compiling movie.
    Accelerated Renderer Error
    Unable to produce frame.
    Writing with exporter: Voukoder Pro
    Around timecode: 00:00:01:13
    Rendering at offset: 0.000 seconds
    Component: Voukoder Pro of type Exporter
    Selector: 9
    Error code: -1609629695
    This issue seems to occur regardless of encoding settings or scene configuration. Even the most basic test exports using default presets fail the same way. I am unable to complete any exports using Voukoder Pro under these conditions.
    Please let me know how to proceed or if there are logs or diagnostic steps you would like me to provide. I appreciate your support as this issue is blocking my ability to use the software.
  • Vouk 28. Juli 2025 um 19:52
  • Send your log file after when this issue happened please.
    Please also answer these questions:
    • Did you perform a scene test of your created scene?
      • Did it work?
    • What version of the FFmpeg DLLs did you install?
    • Note: Connectors are part of "Voukoder Classic"
      • Voukoder Pro uses plugins. Don't mix anything between this two program versions.
      • Make sure you installed the Adobe Premiere plugin in the installer
  • Vouk 28. Juli 2025 um 20:19
