Archival Codec in 16Bit
  • Which codec you recommend for archival purposes, which is uncompressed and supports 16-Bit color depth per RGB channel? FFV1 maybe?
    And do all hosts support 16 Bit or is high color depth limited to specific ones?
    Approved the thread.
    There's not much option for lossless 16-bit and also very limited host support. (even video players)
    Use: MKV (FFV1/FLAC) (or PCM for compatibility).
  • Thank you. FFV1 with 16Bit introduces some heavy dithering patterns, any idea how to avoid these?
