Voukoder 9 only Rendering First Frame
  • I was setting up Voukoder 8 with a friend right now as Voukoder 9 just came out.
    We installed it and tried to Render the thing we rendered before with Voukoder 8. It rendered the first frame and then froze.
    My friend is using a 5700XT with AMD x265 Encoder and CQP 15 both in OBS as in Voukoder/AE.
    Approved the thread.
  • Should be this one.
    You start to Render a File with AMD HVEC x265 Encoder and it just freezes.
    Pressing ,,Anhalten,, doesnt work and its just stuck on the Frame forever
    Original Input File is also x265 AMD HVEC x265
    Heres all the Files that were used.
    https://files.thicc-thighs.de/#/?cd=%2FVoukoder%2F
    *if you get on the Main Site just go to Voukoder Folder*
    Files
    • log.txt
      (7.2 kB, downloaded 20 times, last: )
    Edited once, last by Vouk: Ein Beitrag von Lisa mit diesem Beitrag zusammengefügt. ().
  • Just continue using version 8 until i find a solution.
    (Revoked Version 9 for now)
    Edited once, last by Vouk: Ein Beitrag von Vouk mit diesem Beitrag zusammengefügt. ().
  • The issue is this entry in the AfterFX export dialog:
    It basically tells Voukoder: "Yes, this export should have an audio track." But it never actually sends audio data. Voukoder then waits (forever) for the first audio data so that it knows when to send the container header. This got introduced with the "tmix" change. Not sure how to solve this ... I might have to kick out the "Change FPS" filter, which makes more or less also the "tmix" filter useless ...
    If you set it to "Audio Output Off" it is working fine.
    Added the Label In Progress
    Set the Label from In Progress to Fixed
