render error after effects
    • Official Post
    If you do a sequencial export (one after another) with Media Encoder or After Effects this should be fine. Voukoder can't be used for a parallel export.
    You might send me the voukoder logfile so i can take a look into it.
    Added the Label In Progress
    Added the Label 4
    • Official Post
    Okay, looks like there is something wrong with your settings.
    Can you go into voukoders configuration dialog, check the settings and click okay again to save valid settings?
    Set the Label from In Progress to Not a bug
    Removed the Label 4
