In HEVC (AMF), the i-frame is fixed at about 8 minutes and 20 seconds.
  • I think it should have nothing to do with the AMD driver, because this problem does not occur on another software HandBrake using the same encoder.
    Is log file the big size text next to the output file? Too much redundant information, I have omitted some.
    Quote
    Quote
    Added the Label Fixed
    Set the Label from Adobe Premiere / MediaEncoder to Independent
  • Is this equivalent to the regular adobe premiere setting of "Keyframe Distance"?
    Example: HEVC output of 30fps, with a GOP size of 30 is equivalent to a keyframe/i-frame every 30 frames, so each second has an iframe/keyframe. Correct?
    This will be helpful, thank you!
