Artefact when Rendering
  • Hi, i don't know what happend but sometime i have this kind of problem (See screenshot) when rentagle full of pixel appear, i dont know how reproduce them exactly but only when i select with GPU encoding, with CPU don't happend.... with VK 2.3 and 3.0 have same problem sometime, not ALL the time. on the source file doesn't appear this pixel zone..... Thank you
    I5-3570K 3.8 @ 4.8 Ghz
    16 GB DDR3
    Radion RX580 4GB
  • Yes, these are encoding artefacts. Depending on your encoding you might ...
    • Lower the constant quantizer (CQP) or
    • Increase the bitrate or/and
    • Optimize your encoder settings (i.e. chose a better - slower- preset)
  • Vouk January 19, 2020 at 8:11 PM
    Added the label Not a bug
    Removed the label Adobe Premiere / MediaEncoder
