Important VEGAS Pro Update!
  • I have that box unchecked and Vokouder does not show up. The config file is in the root directory and the plug in is in the Plug-in. I uninstalled and reenstalled Vokouder. No dice. Thanks for getting back to me. Any Ideas?
    I got Vokouder to show up in 2027. However when I click on it I get hdcam as my choices and can not seem to get anything elese.
    I tried the "customoze/cancel" approach as someomne sugested. that does not work. Just stays on hdcam. BTW I got Voukoder to show buy removing the voukoder files from 2027 and brining them in from 2026.
    well it started working and don't exactly know what I did :)
    no it is not working rendering locks up :(
    ok, think I solved it. Voukoder can not be in both 2026 and 2027 for things to work properly.
    Einmal editiert, zuletzt von Vouk (13. November 2026 um 17:16) aus folgendem Grund: 5 Beiträge von dtl mit diesem Beitrag zusammengefügt.
