Voukoder 2026 Not appearing in Vegas Pro 23
  • Vouk 24. März 2026 um 09:24
  • I'm in a similar situation with Vegas Pro 21, Voukoder Pro does not appear in the "Render as".
    I've tried uninstalling Voukoder 2026 and installing Voukoder Pro V2, which showed up instantly. However, the Pro V2 states unregistered at the top. I could not see a way to purchase a license for Voukoder Pro V2 on the website, only Voukoder 2026.
    Did you check this?
    If you have enabled it and it still doesn't work you can try this: RE: VEGAS Pro 23
    I've followed everyone's advise on the thread quoted above including deleting everything Vegas related in appdata/local and CTRL+SHIFT starting Vegas, but it was unsuccessful. The only thing I have not attempted is a fresh install of windows.
    Is it possible to use the license I purchased for 2026 with V2 until this is resolved?
