this is my project. idk where the issues in the log text. thanks before
im give up with this, can you help me? :(
			  Vouk12. April 2022 um 07:36 Hat das Thema freigeschaltet.
 To my knowledge the GTX 1650 doesn't support interlaced encoding anymore.
			okay thanks for your respon. maybe i will render with CPU
			  Vouk13. April 2022 um 07:02 Hat das Label Kein Bug hinzugefügt.
			  Vouk13. April 2022 um 07:03 Hat das Thema aus dem Forum Bug reports nach Closed bugs verschoben.
			Yes, indeed, it's interlacing. It used to bug me a lot as to why that error showed up. I believe the error should be more clear and say "This GPU is not compatible with interlacing encoding. nvidia: 600series to 900series are compatible. AMD: (models here). If you still have to do this, please use CPU encoding. Ortherwise, make sure to change your timeline(s) to progressive field order."
