Premiere Pro beta + Voukoder Pro AV1 video export time takes more than 25min
  • Issue:
    Premiere Pro beta + Voukoder Pro AV1 video export time takes more than 25min on Intel® Arc™ B580 Graphics - Product Specifications
    Application:
    1. Premier Pro beta : 25.4
    2. Voukoder Pro :2.0.14
    3. FFmpeg(GPL) :7.1
    Observation:
    Premiere Pro Release version + Voukoder Pro Version (V2.0.14) on Intel A770 and Intel Panther Lake (No issues)
    Premiere Pro Release version + Voukoder older version ( Offline copy : 13.4.1) on Intel B580 ( No issues)
    Premiere Pro Beta version + Voukoder older version ( Offline copy : 13.4.1) on Intel B580 ( No issues)
    Repro steps:
    1. Install OS and driver
    3. Install Adobe Premier Pro beta (v 25.4)
    4.Install latest FFmpeg and Voukoder Pro (v2.0.14)
    5.Perform the below step
    • Install Voukoder plug-in to export to AV1 format.
      • Download and Install Voukoder plugin from Creative Cloud Dekstop. (search under Stock & Marketplace -> Plugins).
      • Close and open Adobe Premier Pro, if it is already open.
    • Open new project and import media file
    • Press ctrl+F12 to open Console
    • Export the video to 4K AV1
      • For AV1, after clicking Export, under Settings -> Format -> choose "Voukoder Pro".
      • Scroll below to find a Voukoder tab, click configure. A dialog box opens, In the Video tab, under Encoder -> Codec -> Choose AV1 (Intel QSV). Click Apply and OK to close the dialog box.
      • Back in the Export window, under Video Settings -> Frame Size select 4K.
    • The export video should playback no issues
    • Issue Observed
    Experiments:
    1. Inspected GPUView of failing case, low activities of copy/media engine are seen. Need to figure out why do copy numbers so low.
    Failing case: Intel B580
    Working case: Intel A770
    2. Inspected Voukuder log of working (Voukuder 13.4.1) and failing case (Voukuder Pro 2.0.14), in failing case, FFmpeg input per second (3 fps) at the very beginning is much less than that (47 fps) in working case, which could explain low copy numbers I observed in GPUView.
    Working Voukuder log: 1M20S Effect Video 420_6.txt
    Failing Voukuder log: 025-08-28_00-41-42.txt
    3. Tried FFmpeg hardware acceleration transcode on Intel BMG with the arguments in Voukuder Pro 2.0.14, transcode works fine with average 42 fps
    FFmpeg command line is as follows:
    ffmpeg -hwaccel qsv -hwaccel_output_format qsv -i "C:\Users\Local_Admin\Downloads\LenovoTestCase\Premier_420\PR_YUV420\Copied_Pr_YUV420\C0232.MP4" -vf "vpp_qsv=framerate=60,scale_qsv=w=3840:h=2160:format=nv12,hwdownload,format=nv12" -c:v av1_qsv -pix_fmt nv12 -time_base 1/60 -aspect 1:1 -global_quality 25 -q:v 1 -g 12 -bf 0 -c:a aac output.mp4
    Between the arguments in Voukuder Pro 2.0.14 and those in Voukuder 13.4.1, there's no big difference:
    ffmpeg -hwaccel qsv -hwaccel_output_format qsv -i "C:\Users\Local_Admin\Downloads\LenovoTestCase\Premier_420\PR_YUV420\Copied_Pr_YUV420\C0232.MP4" -vf "vpp_qsv=framerate=60,scale_qsv=w=3840:h=2160:format=nv12,hwdownload,format=nv12" -c:v av1_qsv -profile:v unknown -preset veryfast -pix_fmt nv12 -time_base 1/60 -aspect 1:1 -global_quality 25 -q:v 1 -g 12 -bf 0 -c:a aac output.mp4
    Therefore, I don't think this is not simply BMG issue.
    Questions:
    Could you compare the Intel QSV AV1 codec arguments between Pro version 2.0.14 and version 13.4.1?
  • Vouk 29. August 2025 um 13:01
