Hey,
would it be possible to get 2 pass enccoding for libx265?
Greetings
2 Pass x265 Encoding
- Geplant
renvan -
24. August 2025 um 15:53
24. August 2025 um 17:51 Hat das Thema freigeschaltet. -
Technically it's possible, but i didn't implement it yet as it slows down the overall encoding process and there are much better rate control algorithms available (i.e. CFR). What do you need it for?
I am remastering 1080p footage to uhd hdr10. Using 35mm grain causes exploding high bitrates around 50-60Mb/s with CRF 18 or 19.
Ok for UHD Discs but not an option for streaming ready encodes.
Yes, if you want to get a certain video size it's a good reason. I'll put it on my list.
24. August 2025 um 22:45 Hat das Label Geplant hinzugefügt. -
Thank you very much!
