How to create a bug report
  • These are some guidelines for you on how to create a correct bug report.
    • Check the forum if a bug report for your issue already exsists. If so, use it. Otherwise you may create a new topic.
    • Describe the issue as detailed as possible. I can not see your screen so I rely on your input.
    • Provide steps on how to reproduce the issue.
    • Attach your log-file (You can find your log-file under Settings > Log file.
    • You may also add screenshots if it helps to illustrate the issue
  • I get the following error in Adobe Media Encoder when exporting with NVENC in HEVC but only if I select the 10bit option under the Voukoder menu. If I select 8bit I don't get the error and the file encodes fine....
    xport Error
    Error compiling movie.
    Export Error
    Exporter returned bad result.
    Writing with exporter: Voukoder R2
    Writing to file: E:\04-28-19 06 Phx Rising vs Classic SC_8.mp4
    Around timecode: 00;00;00;02
    Component: Voukoder R2 of type Exporter
    Selector: 9
    Error code: -2147483648
  • Post by lmarcelo ().
    This post was deleted by Vouk ().
  • Post by Vouk ().
    This post was deleted by the author themselves ().
  • Post by avwtp ().
