VOUKODER 1.2.1 - NVENC is missing ?
  • Hi !
    I've just upgraded to VOUKODER 1.2.1 from 1.1.3 and NVENC is missing... I use Premiere Pro 2019, I had to roll back to 1.1.3 to get NVENC available again.
    Does it mean NVENC is not available anymore on newer versions of VOUKODER ?
  • Nvenc in Voukoder 1.2.1 doesn't work, but in Voukoder 1.2.0 works.
    Driver Provider: NVIDIA
    Driver Date: 2019-01-11
    Driver Version: 25.21.14.1771
    (i. e. 417.71)
    1.2.1 voukoder.log
    Loaded lib: nvEncodeAPI64.dll
    Loaded sym: NvEncodeAPICreateInstance
    Loaded sym: NvEncodeAPIGetMaxSupportedVersion
    Loaded Nvenc version 8.1
    Driver does not support the required nvenc API version. Required: 9.0 Found: 8.1
    The minimum required Nvidia driver for nvenc is 390.77 or newer
    Nvenc unloaded
    1.2.0 voukoder.log
    Nvenc initialized successfully
    1 CUDA capable devices found
    [ GPU #0 - < GeForce GTX 1060 6GB > has Compute SM 6.1 ]
    supports NVENC
    Nvenc unloaded
