Auto Select Settings from sequence?
  • Can you allow us to auto select the source/Sequence settings during the export? It doesn't seem to read the sequence settings and i end up having to update all them. This isn't really a major problem, but it is kind of annoying.
    Maybe add the option to copy source settings like the original encoder does?
    [Blocked Image: https://i.imgur.com/IJ7HPNs.jpg]
    There is what i'm talking about. You can make auto fill in the sequence settings on the original encoder. While i have to go in and edit it manually each time using voukoder.
