Adaptive language
  • I've viewed the code and found you currently are using English-only in your source code
    Can you separate all the text into variables so that it can be displayed in many languages?
    Is it possible to detect current Premiere/AME's language and then load translation files?
    Don't worry about you don't know other languages, the translation can be completed by volunteers, it would be better if you use third-party platform to help improve the translation (e.g. Crowdin)
    Set the Label from Feature Request to Done
    Set the Label from 1.x to 2.0
