After video is exported, there is a link "www.voukoder.org " in properties of a video file. Is there some way to not show this link in properties?
Is there some way to have a clean metadata?
- 1.x
- turbosmile
We need it in production, and we can't have this link in properties of a videofile. Hope you understand.
I want to keep this meta-data in the opensource and free version of voukoder to promote and spread the knowledge about it.
But i have the idea of payed "custom builds" in mind. I will think about it and write it down later.
You can remove or add metadata with other tools if you really need it.
I really need it, can you tell me what tool i can use to remove this metadata? And i have a doubt that this link is in metadata, because it's written in "Writing application :"
Sorry, i don't mentioned it, Please think about this. it will be very nice to buy your custom build.
The simplest way is StaxRip I think, its opensource and easy to use.
- Open the video file
- On the right side select Copy/Mux and a Container Format (I prefer MP4 from mp4box)
- On the bottom right side for Audio select Copy/Mux too
- Now Click on "Container Configuration" got to Options and clear the textfield named "Tags"
Version 1.2.2 will have "cleaner" metadata and only report the application name and the version number. i.e. "Voukoder 1.2.2"
All other changes still require a custom build.
Added the Label 1.x
