FASTEST H.264 mp4 ENCODER EVER!! But Constant Rate Encoding has not worked in many versions-very pixelated even at high bitrate. Variable is fine.
  • FASTEST H.264 mp4 ENCODER EVER!! But Constant Rate Encoding has not worked in many versions-very pixelated even at high bitrate. Variable is fine.
    i did donate:-)
    Steve from NY
    Can you please tell me the exact settings and the exact encoder you get bad results with?
    i did donate:-)
    Yes, I remember! :)
  • Hi Dan, Happy New Year!! The last version that didnt pixelate during CBR encoding was version 0.8.1
    pc WITH WINDOWS 10, nVIDIA gEFORCE gtx 960
    I am now using version 1.1.3 VBR & it seems to be fine so far.
    My settings are this:
    I do love the "estimated File Size" you added so i only use settings that allow that
    Video Encoder: NVIDIA NVENC H264 encoder
    1920
    1080
    aspect: square
    Frame Rate: 29.96 NTSC
    Field order : None Progressive
    TV standard: NTSC
    Color Space BT.709(HD)
    encoder options
    color format: YUV 4.2.0
    Preset: default
    Profile: High
    Level: auto
    Bitrate: 15,000 & sometimes 20,000
    Buffer size: 12 kb
    RC Lookahead: 0
    AUDIO:
    ACC
    4800 HZ
    STEREO
    ENCODER OPTIONS-AUDIO
    pRESET: LOW COMPLEXITY
    bITRATE: 192
    wORKS FINE WITH THESE SETTINGS IN VBR but in CBR the video totally falls apart. Huge pixels & low quality even at 20,000 bitrate.
    Thanks Dan:-)
    Hat das Label In Bearbeitung hinzugefügt
