18 FPS frame rate support
  • Hello, I have seen the good progress on additional frame rate support, however there is still lacking the standard for 18fps Super 8 film. Can this also be included? Possibly add 18fps menu option, also possibly a custom frame rate checkbox to enter frame rate manually, or button to "Match Source" like other export encoders do in Premiere Pro and Media Encoder. I also noticed that "Maximum Depth" the standard encoders have is missing from this one.
  • Yes, I will add 18fps mode. Entering a custom framerate is a little difficult because Premiere expects the framerate in a fraction. like 60/1 for 60 fps or 60000/1001 for 59.94 fps.
    "Match source" is not supported with CS6. There is a non-CS6 build on the nightly builds though which should support the "match source" functionality. Voukoder 2.0 will support this by default (and not CS6 anymore).
    Added the Label Done
    Added the Label 1.x
