How to create ingest settings in adobe encoder with Voukoder and use for creating a proxy ?
    I try many times to create ingest settings in media encoder and then try to create proxy with this ingest settings based on Voukoder. When I send render to media encoder, render start encoding but on the finish is crashing. Do you have the same advice, how to do it?
    Windows 10
    Intel Core i7 2600K 3,4GHz
    16GB ram
    Nvidia GTX 770, 416.16 drivers
    Adobe CC 2018
    Adobe Premiere CC v12.1 last update
    media encoder log error
    - Doba kódování: 00:00:25
    10/09/2018 11:24:46 AM : Kódování se nezdařilo
    A low-level exception occurred in: Voukoder 1.1.0 (Exporter:9)
    Chyba exportu
    Chyba při kompilaci filmu.
    Chyba exportu
    Došlo k výjimce nízké úrovně.
    Zápis s exportérem: Voukoder 1.1.0
    Zápis do souboru: E:\RENDER_TEST\DJI_0002_Proxy.mp4
    Okolo časového kódu: 00:00:20:44
    Komponenta: Voukoder 1.1.0 typu Exportér
    Volič: 9
    Kód chyby: 3
  • Koopy
    Changed the title of the thread from “How to create ingest settings in adobe encoder with Voukoder and use for creating a proxy” to “How to create ingest settings in adobe encoder with Voukoder and use for creating a proxy ?”.
    Added the Label Not a bug
